Revision 3 MR2 Turbo for Sale (Needs repair)
sutats
Post by sutats »
Hi folks!
For those with the mechanical or financial ability. I have been the only owner of my trusty JDM rev 3 MR2 GTS turbo since it landed in the UK. It has very recently sustained some drive train related damage and now I'm selling it because I just don't have the resources to repair it to a driveable state again.
The engine chuggs loudly at 500 rpm when idle and must be repaired before it is driven.
It has stock standard specification except for a blow off valve and a carbon fibre shifter and a K&N performance panel filter and aftermarket 16inch rims. It also has an ultra high end aftermarket Autowatch immobiliser/alarm and clutch which was recently replaced by 3S Service Centre (MR2 specialists). It has under 140000kms (< 87000miles) on the odometer. As you may already be aware this is a revision 3 turbo which means it has 250ps as standard and LSD for superb cornering traction. This is a 5 speed manual vehicle. The car has some scrapes and dings and is definitely not a shiny showcar.
Let me know your offer if you are genuinely interested. I've excellent eBay feedback 1000+ 100%positive. The car is located in Manchester. Thank you.
Now advertised on eBay.
