Hi Rob,
Got those mirrors about six months ago
(£7.50 on ebay USA).
They do look like horns and I had to slice about 25degrees off them to get them flat with the floor.
Got them perfectly square to the car and then couldn't see behind from the driver side, so had to seriously adjust it further so that I could see out of both and so that they both looked the same from the front even though the passenger is at this sort of an angle
\ and the drivers also tilted
Will get some pics up for you as they are being fibregalssed at the mo and have had the top split blended in.
Defo need spacers on the rear though.
.sorry but I've just put the Modena rear on which has the veilside flare on it
(or rather had, as it's been removed and blended to match the Bomex skirts) and a set of V skirts and couldn't believe how sunken they made the back wheels look.
Marc
