sorry you guys for the crap english
i only just got the kit and was abit to excited
well i have manged to wire them up and all is working.
this is what i have done.
1 with the wiring loom there is a multi plug.
that fits to the orignal light socket
(this sets the relay to start up the hid on low beam)
2 plug the loom in to the ballast and the ballast to the light
(this supplies the hid with the power which is controled by the relay.
3 now we got low beam sorted the only thing remaining is to set up is the flash lights.
from the wiring loom on the multi plug are 2 wires which i can only assume control the flash light.
from the bulb there are only 2 black wire which should be for the flash light.
wire the blue and black from the
(loom) multi plug to the black wires and.
.hey presto that should light up the fogs
as for the other side
(from the bulb) you should have 2 black wires like the other bulb.
with one of the multi plugs they supply fit them in the hole parrallel to each other and plug in to
multi plug socket from the car
hope this is clearer.
it worked for me
