K-Sport Coilover kits for MKII
Forum For IMOC Group Buys
Greddy-Matt
Post by Greddy-Matt »
Hi all,
Right as we have several people interested in the coilover kits from K-Sport, Bren @ Apex Performance has kindly offered us a discount on the MKII kits. See the website for more info :
www.ksport.co.uk
or
http://www.ksport.co.uk/order.asp?id=254&loc=1
Please refer to Bren @ Apex Performance for any technical spec, or question, their details are at the bottom of this post....
The discount is offered on the basis that 5 or more complete kits are ordered
Prices are as follows:
Regular coilover kits
Usual RRP = 694.97 inc VAT
Group Buy Price = £521.47 inc VAT!!! (25% discount)
Inverted type kits
Usual RRP = £895.30
Group Buy Price = £716.24 inc VAT (20% discount)
Both sets include adjustable top mounts.
I have just emailed Apex performance to confirm if there will be delivery costs etc, as soon as i know ill post up the details.
Ideally, I want to get these on order as soon as possible so if anyone wants in on this please post your name up! Delivery is aprox 2 weeks, and ill place the order as soon as we have five orders ready, but will keep the group buy open so that anyone else that wants a set can take advantage of the discounts! :D
Ill be checking the group buy as often as i can, unfortunately my internet access is very limited at the moment so please be bear with me guys n girls :oops:
Regards
Matt - (p.s if anyone in the guildford area needs fitting i have found a place localy that will fit for a bargain price, PM me if you want their number)
Contact details for:
Apex Performance Parts Ltd
Tel: +44 (0)1274 683633
Fax: +44 (0)1274 683636
Unit 4D
Wharfedale Road
Euroway Industrial Estate
Bradford
BD4 6SG
Greddy-Matt
Re: K-Sport Coilover kits for MKII
1). Cadaver - regular set for road
TheRoadWarrior
Post by TheRoadWarrior »
I know you put contact apex for more info, but its late, they're closed and I want more info!!
do you know what the benefits of the inverted type are? I see you've said you want the 'road' biased kit, what's different, the spring rates, or something else?
Greddy-Matt
Hi,
The chap at apex is away till monday unfortunately, but here's the link you need, it looks like its for seperating oil and gas in the cylinder tho:
http://www.ksport.co.uk/products.asp?f=coilovers
The regular coilovers come in either fast road or fast road/track
and the damping is adjustable on both but matched to the spring rates or something like that, the road set up is apparently a little more forgiving. :D
TheRoadWarrior
thanks for the link, I might be interested.. but I need to check it out further.
jonb-
Post by jonb- »
Those are fairly high spring rates. Tein HA's are 4 & 8 kg/mm, so those at 4.5 and 7.2 while better balanced for sure are still going to be quite stiff.
Try and get Bren to answer questions here. I'm interested to know the valving and spring rates on their 'track' version as my HA's are too soft for my application now and i'm in the market for something new.
TheRoadWarrior
I'm very tempted by the GT PRO kit, price seems good for what 'looks' like some decent suspension tech and at a price comparable to shocks/springs/topmounts.
Thing that troubles me is that no one in the mr2 community, and few outside that has any experience of them.
Does anyone know if the GT PRO kit has the same method of attaching the droplink as the standard Kontrol coilover? Its a threaded collar on the shock body, rather than welded on- looks like it could come loose and spin causing the droplink to contact the shock body <- just speculation.
Very interested tho Matt!
nick200
Post by nick200 »
Also interested, since very good price for coilovers - but wonder if we can specify softer spring rates ?
Drop link attachement / issue as mentioned by Roadwarrier - a good point, also what is the max drop available on these coilovers?
Draven
Post by Draven »
I'm also in the market for some coilovers... I want to know wether these would be better than some Tein Superstreets for road use... ?
Any ideas... at that price do they include drop links..
I guess thats not with top mounts.. do they fit on the standard ones ?
Draven
Post by Draven »
Ahhh called them.. It does include pillow ball topmounts..
Blokey in the know was having his dinner.. :shock: so i have to call back in 45 mins..
jonb-
Post by jonb- »
CADAVER wrote:Hi all,
Ask him something useful this time draven!
Draven
Post by Draven »
:shock: i'm incabable of reading..
no need to be so harsh..
nick200
Post by nick200 »
spoke To Apex today regarding the spring rates, and do you want the good news or the good news ?
Within reason you can specify what spring rate you want ( the actual rate needs to be verified with Ksport before ordering, which is fair enough ) and this is done for the same price !
custom spring rates. adjustable damping and the best coilover price around !
count me in for sure :D
nick200
Post by nick200 »
2) Nick200 - spring rates tbc
Greddy-Matt
Hi guys, thanks for the interest! Sorry i've not been able to log on sooner, has anyone called apex regarding the drop mount instalation? FYI i dont thing there is a problem with the regualar set ups as another IMOC member has these and didn't mention anything, ill drop them a PM to be sure tho... :D
drew3555
Post by drew3555 »
Nick200,
Do these drop the car as much as we need???
BTW - Dampertech do the custom build ones in a street set up withe the required drop for our needs at 500 for the set. (did you get my last PM on the other site?)
nick200
Post by nick200 »
Hey Drew, good point about the drop, will call Apex tonight and check on max drop and also how the drop links are attached.
I've ordered loads of stuff through Apex before, for the 200sx and their service is 2nd to none - hence not going through the other route.
will post result when called,
cheers
Nick.
Greddy-Matt
Nick your a star, thats 2 so far then, come on guys n girls get your names down :D
2Crooky
Post by 2Crooky »
Bummer!
Saving up for my new wheels :( How long will this group buy go on for mate???
alex
nick200
Post by nick200 »
shine ....
Spoke to Apex and basically you can go as low as the car allows !
The chap couldnt say 100%, but was sure the droplink attachment was on a threaded collar to allow adjustment. With my limitated suspension knowledge doesnt this need to be the way anyway to allow adjustement ensuring there is always an angle on the links compared to the horizontal ?
Return to “Group Buys - MR2 related”
