I have 15x7 rears with 35 offset so they fit further out by 10mm I believe
Whilst I'm asking anyone know if all bootlids intended for spoilers
Thx for any info.
R
BLZ-8027 wrote:Hi mate sorry to butt in on your thread but do you know if split rims have a different offset i;e outer and inner
rob shipp wrote:Hey all.
I have 15x7 rears with 35 offset so they fit further out by 10mm I believe(is this correct, standard is 45 on a
'90 uk t-bar?).
My question is can I use a 10mm spacer either side to bring them closer to the front look
(same wheel so 24mm further out than standard.
.looks just right in the arch).
What does this spacer do to the offset and is it ok for the rears.
Also where do i get
'em?
rob shipp wrote:Whilst I'm asking anyone know if all bootlids intended for spoilers(ie.
all revs) share the same holes for fixing the spoiler.
I know the 3 piece rev1 and 2 will have more holes.
Thx for any info.
R
Turbo-G wrote:BLZ-8027 wrote:Hi mate sorry to butt in on your thread but do you know if split rims have a different offset i;e outer and inner
Search for the deffinition of offset(on here somewhere I believe) and the answer will be blindingly obvious to you.
.and unless I am mistaking your question
(in which case someone will correct me) but the answer is
'no'.
Leeroy wrote:Well standard offsets are 35-> 38 on the Mk2.
cantfindausername wrote:isn't the 35-38 because people want wider wheels?![]()
Leeroy wrote:http://www.imoc.co.uk/forums/viewtopic. ... sc&start=0
Take a look at this sticky..
Appears the offset is probably 45, although its slightly confused!
Andy Jones wrote:Leeroy wrote:http://www.imoc.co.uk/forums/viewtopic. ... sc&start=0
Start off a sticky with the wrong info![]()
I ammended a bit futher down
blackspider wrote:On the"other" site it says the most common set up for 17" wheels are as follows:
17x7 ET35 205/40/17 or 215/40/17 front
17x8 ET35 235/40/17 or 245/35/17 back
17x7.5 ET35 215/40/17 front
17x8.5 ET35 245/35/17 back
So is ET35 the best offset for an ideal fitment on 17's?
BLZ-8027 wrote:The reason i asked if split rims have different offsets
is that i have just bought some wheels which are 16inch
two wheels are 8inch and two are 7inch
with 205 and 225 tyres
i haven't cleaned the wheels up properly yet but the only offset stamped on the inside says offset 06
not seen this before but then again never bought split rims before
