Rev 3 stuck in safe mode.
Maidens
Post by Maidens »
Hi,
My rev 3 has been stuck in safe mode for a while now. I've been getting past it by using a boost valve, but decided on the weekend to have a look at the VSV and do the checks to it. It works fine, so what would be the next checks? Plus I've reset the ecu and disconected the battery with no luck.
Any help
Paul
ballmysta23
Re: Rev 3 stuck in safe mode.
Post by ballmysta23 »
hello mate,
this recently happened to me.
have you done the diagnostic check??
all you need is a paper clip, put one end in the Te1 connector of the diagnostic port, and the other end in th E1 conector.
when you turn on the ignition (without starting it) the safe mode light will flash. if it flashes repeatedly at the same speed (twice a second) then everything is fine.
yours should do a routine amount flashes.
it will flash for eg twice pause and then 4 times, that is code 24 which stands for intake air temp.
so you might more than one code so keep making note of all the codes, until it repeats itself.
mine came up with six codes once, but after doing some checks it came down to only one the KNOCK SENSOR code 52.
well let me know what codes it brings up and i should be able to give you what faults you have.
ps. i'll be leaving for work by 4:30 this after noon, but back on tomorrow.
hope this helps
ian
