Bottom End Bearing Help
B17AD K
Post by B17AD K »
I stripped the car down to change the BEB's, and found that the ones in were quite fooked.
So, went to put the new ones in that I'd ordered, and they were too big.
Now, I told the supplier it was a 1991 Mk2 Mr2 Rev1 Turbo...3S-GTE and Sw20 Chassis.
So, does anyone have the part code for these, and the number of a supplier?
I was also told that Rev1 bearings and Rev2 bearings are the same, is this also true?
Andy F
Re: Bottom End Bearing Help
Post by Andy F »
I would go to toyota with your VIN and let them order them, there are a few different sizes.
Built by YVS Performance
Every car that leaves runs 2 bar+
cantfindausername
Post by cantfindausername »
It tells you in the BGB how to get the sizes off the block and crank.
***RIP Car13 ***
*** Now in an Evo ***
B17AD K
Post by B17AD K »
Because Toyota said it would take a month to get the parts in, and I don't fancy waiting that long.
So im using a different supplier, but as I said they have already supplied the wrong ones, so I'm trying again.
B17AD K
Post by B17AD K »
The supplier has said that they can't get them...
So it's gonna have to be from Toyota.
Problem is, I don't know if my engine is Rev1 or Rev2.
Can someone please confirm if the bottom end bearings are the same on each version?
Stuart
Post by Stuart »
The bearings on the REV 1, 2, and 3 are the same. You shouldnt have any problem getting them from any Motor Factors for about £80 a set.
You can get them from Toyota but expect to pay £280 for the same set. Ive been told by my local Motor Factors that using standard bearings will be fine as long as your crank isnt damaged / worn. If your crank has been damaged then I would recommend that you get it ground and have new bearings matched to that.
Andy F
Post by Andy F »
Stuart wrote:The bearings on the REV 1, 2, and 3 are the same. You shouldnt have any problem getting them from any Motor Factors for about £80 a set.
You HAVE to order the bearings by matching the numbers on the crank (big end) and block (mains) if you ring Fensport they will probley have them in stock, and they will ask you for these numbers.
FFS
B17AD K
Post by B17AD K »
Toyota said about 80 quid.
But, when I rang they said about the numbers.
But at least I know now, and ive got the numbers.
Two number 1's, a 2 and a 3. :)
Do you have a number for Fensport?
Andy F
Post by Andy F »
+44 (0) 1354 696968 or +44 (0) 7000 336776
Lazy git :clown:
B17AD K
Post by B17AD K »
Ty :)
^Trickster^
Post by ^Trickster^ »
When you say the bearings are fooked, you mean they are just worn? Or has one actually span?
I would never replace a set of big end bearings without having the crank and rods checked and polished and measured for size.
Ive seen people swap out bearings alot of times and they have shot a rod within 500miles.
Just a word of concern thats all.
Graeme
Andy F
Post by Andy F »
What do you put your big end problem down to Graeme?
I read it went at York the other week :(
^Trickster^
Hey Andy
Hope your ok and the car is running well :D
Rod bolt failure was the culprit, pretty much a clean snap on the head of it. Should of fitted ARP, but you live and learn mate.
Got some big plans for the 2, but in no rush as ive just bought a house with my girlfriend, the car can wait, give me time to get other things on it sorted too :)
Regards
Graeme
Andy F
Post by Andy F »
Im good thanks mate 8)
The car is almost there, just getting the god damned cams set up..(properly)
Shitty luck with the rod bolt, i heard the one's on the group A rods can snap too!
Good work getting the house, hope its got a double garage :eye:
^Trickster^
Cheers mate :D
Just a single garage unfortunantly! But its a decent size, its well big enough to work on the car, but i have my warehouse which holds about 12 cars where I have my car anyway, so pretty lucky that way!
Just getting my parts together slowly :D
Regards
Graeme
cantfindausername
Sorry to thread jack...
I'd like to know what the numbers corrispond to on the crank and the block.
I've got the numbers 0 0 1 1 1 on the crank and 1 1 1 1 1 on the block, but what does that tell me with regards to bearing sizes?
Anyone have any pearls of wisdom on this?
Thanks,
Ant
***RIP Car13 ***
Andy F
Post by Andy F »
You need 11111 bearings to match the 11111 block and same with the crank, i think there are 3 or 4 different sets of numbers, but if your using your existing block and crank you should be able to give your VIN to toyota, the problems start when your using rev1/2 blocks and rev3 crank.
Plasti-gauge is always a good idea to double check :)
cantfindausername
I'm using TOGA HP bearings in "Standard" size. Been trying for ages to see how these match up with the Toyota sizing system on the US board. Its become apparent that the MR2 BGB section for this is complete BS.... just one big typo :lol:
Gonna try and measure them up this weekend so should know soon enough.
***RIP Car13 ***
