Just a few questions really;
1.
2.
Thanks for any help you can give.
Cheers,
p.s Is there a carbon fibre TRD spoiler available? or something similar?
Michael.
msherry21 wrote:Hi, How are you all doing?
1.Has anyone put a 6 speed gearbox in a MK2 MR2? Would this be possible and would it be worthwhile? any info appreciated.
2.Has anyone twin turbo'd a MK2, Like a Supra? Would this also be possible and worth while doing?
Thanks for any help you can give.Just trying to do something a bit different really.
Cheers,
Michael.
Gazboy wrote:I'd kill for a 6spd box, 5th is too short for motorway use'when pressing on' without consuming vast quantities of motion lotion.
stevecordiner wrote:You could fit a longer ratio 5th gear from a celica- that would make 5th a bit more motorway friendly
Paul Woods wrote:the 6 speed mk3 box(c60 i think its called?) has been fitted onto a 4a-ge in the states,next year im going to look into the possibility of fitting this box onto my 3vz-fe,this is relevant to this post cos the 3vz-fe shares the same bellhousing pattern as the 3s-gte meaning if i get one of these 6 speeders to fit my V6 it'll fit your mk2's as well.
.the only issues yet to be resolved are driveshaft fitments and wether or not it will handle the power,watch this space.
Paul Woods wrote:yeah i do have the camry V6 installed,the manual version is the same except the gear linkages are on the wrong side of the box but the bellhousing pattern and clutch config is the same as the turbo.
Paul Woods wrote:
Anyone know what power/torque the 6 speed celica box will easily handle?
