limits!!!!!!!!!
limits!!!!!!!!!
could someone pls tell me where the limiter is and how to loose it on a j reg mk 2 import
Re: limits!!!!!!!!!
Hi,
You need to get a delimter basically, these also usually convert your reading from KPH to MPH as well.
http://www.twosrus.co.uk/product_info.p ... cts_id=192
You can get cheaper ones but as the power steering is also dependant on the speed signal, I wouldn't bother...
HTH,
Nik
HTH,
Nik
Re: limits!!!!!!!!!
its already in mph does that mean anything whats the best way to tell if it has already been done??
Re: limits!!!!!!!!!
Not necessarily, the previous owner may have just fitted MPH dials.
- Scott Barton
- IMOC Committee
Re: limits!!!!!!!!!
I 'lost' my limiter after having my Unichip fitted.
Damned if i can find it again.....
Re: limits!!!!!!!!!
IANSMITH wrote:its already in mph does that mean anything whats the best way to tell if it has already been done??
110mph dials by any chance? If so it's still in kmh and the odo will be working in kms too.
ScottBarton wrote:I 'lost' my limiter after having my Unichip fitted.
Not cheap tho eh?
Re: limits!!!!!!!!!
Same here with the motec, found it again at 155 at TOTB last year on the rev1 box. I'd love to find it again now on the modified rev2 box though.
Re: limits!!!!!!!!!
180 is on the clock.??? that mean anything?
Re: limits!!!!!!!!!
Mark Edwards wrote:ScottBarton wrote:I 'lost' my limiter after having my Unichip fitted.
Do the rev1/2 boxes run out at 155? I thought they were meant to go up to around 168 lol
Scott =op
Re: limits!!!!!!!!!
Rev1 box has lower gearing. Rev2 on are the same though, about 163 is meant to be the limit.
Re: limits!!!!!!!!!
Ahh right IC. Is it a big job increasing the final drive of the gearbox? In other words is it a lot of spondoolies if your not doing it yourself?
Scott =op
Scott =op
Re: limits!!!!!!!!!
Yes.
The parts were over £300 but Andi and myself did all the work.
