How easy is it to remove the ariel? later this year i need to do a full respray
down the sides and fill in the holes where the old corners used to be... currently has gromets in to stop water getting in till i can afford a respray.
The ariel doesnt work anyway so i want to get rid of it
ariel removal
Re: ariel removal
start by twisting the nut on top anticlockwise, undo the bolt holding it inside and it should all pull through then replace the nut on top very important!
...or get another from a scrappy like I did.
