Ignition timing Mk2T
nutter
Post by nutter »
Hi,
When i was having my cylinder head repaired the guy took my distriduter off. He didn't mark it though :(. Is there any way i can set the timing roughly so at least i can start the car. Then i can time it properly using the light.
Merlin
Re: Ignition timing Mk2T
Post by Merlin »
undo the bolts, and try to get the bolts u can see easily dead center thats the best way, then get it done properly asap
regards
Rob
Fonzy
Post by Fonzy »
:lol: sorry for the hijack but morning Rob, do you have a timing gun?
Merlin
Post by Merlin »
of course i do! lol virtually the same one as Snap-On
need to borrow it at some point??
off to work now cya
Fonzy
Post by Fonzy »
yes mate, someon called vern in oz is making me up a map, using my spec list, and at that stage i dare say i (or we) :) might need a timing gun! Lol, im sure you know how to use it! :wink:
BenF
Premium Member
Post by BenF »
... you mean the complete mechanical dizzy?
Its got locating lugs in it so it can only come out / go on in a particular way - the ECU will sort itself out.
Timing wise, if its at idle you can fairly much just slap the dizzy back on, link T1 and Te1 and set the timing back to 10deg btdc . Don't drive it or put the engine under load though
^Trickster^
Post by ^Trickster^ »
Just go to halfords and pick up a timing light, they are only about 30 quid, ive used that and checked it with my mates snap on and its spot on.
Graeme
Merlin
Post by Merlin »
oh yes fonzy i know how to use the old timing storbe lol
Jimbo
Post by Jimbo »
Just spelling it that causes you problems eh? :lol:
Merlin
Post by Merlin »
:oops: Strobe 8)
