calling all gurus!
Fonzy
calling all gurus!
Post by Fonzy »
hi chaps can someone tell me where in the 1342 firing pattern the sync pulse occurs?
:D cheers, Fonzy
JJ
Re: calling all gurus!
Post by JJ »
Yes !
1342 :lol:
Its a conventional firing order on these engines ! :wink:
Fonzy
Post by Fonzy »
JJ can u point out the middle 2 numbers for me cos my eyesight is a bit weak these days
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
mate is there a sync pulse that fires after the 2???
JJ
Post by JJ »
Sync pulse... are you talking about synchronisation in the cams with the bottom end / crank @ TDC ??
Absolute sync will occur 720 degrees - 2 complete rotations of the crank will line up the cams to the original point you started off with.
Does the link work off the distributer to work out the crank position or is it looking for a crank position sensor ???
If I remember, a tooth needs to be removed in the distributer on some systems :shock:
Fonzy
Post by Fonzy »
it can use the distributor to identify rotation of the crank so thats ok, but the manual uses the term sync as a referance point to any trigger/switch/or marker point identifying the start and finish of full rotation of the crank with reference to the wiring of injectors,
Its all abit strange, the ecu understands the rotaion of the crank but still insists that you must wire the injectors up in the firing order following the cycle of the trigger point, so if the cync point occurs between 1 and 3 i would wire the injectors different than if the cync point occured between 3 and 4.
This is mental!
I am assuming the the cync point is after 2 as 2 is last in the firing order, but as it quite clearly demonstartes in the manual you cannot make these assumptions.
Having spoken with a really nice bloke at Millway we have established that the ecu is looking for double info, and even so it doesnt matter cos wherever the syn point is eventually it would all catch up with its anyhow, it seems as though this sync point is really just to ensure first crank start up.
so now ive confused myself and evryone else, ive decided on my original theory.
Injector cable number 1=1 2=3 3=4 4=2 all that makes sense doesnt it? :twisted:
PW@Woodsport
Post by PW@Woodsport »
sorry for the hijack....JJ ive got my old turbo engine out,was indeed oil pump failure and the bottom end has gone on cylinders 1 and 4 which also have strange pitting on top of the pistons.
To the point,is the old engine any use to you? free of course,just id rather you made use of it than the scrap man get it,theres a complete rev2 head there as well and loads of other bits you might be able to salvage,let me know dude.
JJ
Post by JJ »
Big fellar, reserve it for me if you can, I'll sort something out with you soon about it !
Fonzy ............... bloody hell !! you've just stepped on the steep slope of engine management knowledge.
I hear what your saying and from what you've said :
"Injector cable number 1=1 2=3 3=4 4=2 all that makes sense doesnt it?"
it seems feasible..... if a little unusual to be switching the injectors position.
The sync signal need to happen otherwise the ecu won't start the firing and fuelling sequence ... one of the reasons why the engine turns over 2 times ( 4 groans from the engine ) before it'll start in any modern day efi car.
Any progress today ???
Fonzy
Post by Fonzy »
yeah the only progress is you confirm what i thought, but do you think its safe to assume the signal comes after 2 and before 1 ?
Fonzy
Post by Fonzy »
also i can tell u the link ecu is proper standalone definately not plug and play, having looked at the software its very simple to use too! i intend on learning alot more about engine management and want to be able to tweek it myself after the initial power tune. Its a damn good bit of kit even if a little complex to wire in. :P
JJ
Post by JJ »
Fonzy wrote:yeah the only progress is you confirm what i thought, but do you think its safe to assume the signal comes after 2 and before 1 ?
I'm sorry, I've malfunctioned !!! :lol:
Sync signal should happen bang on 1 or am I missing something here !!
Why don't you move to the north james, it be far easier !!! :lol:
Fonzy
Post by Fonzy »
Toooooooooooooo cold up there 4 me! :lol:
Then if its 1 wired them right! :P
PW@Woodsport
Consider it reserved,theres also a box full of rev3 gearbox bits and a load of turbo bits n bobs id like you to take off my hands.
