This simply means that the oil falls into 2 viscosity grades, in this case 10W
This is made possible by the inclusion of a polymer, a component which slows down the rate of thinning as the oil warms up and slows down the rate of thickening as the oil cools down.
It was first developed some 50 years ago to avoid the routine of using a thinner oil in winter and a thicker oil in summer.
For a 10w-40 to attain the specification target a 10W
This is important because a thinner oil will circulate faster on cold start, affording better engine protection.
For a 10w-40 to attain the other specification target a 40 oil must fall within certain limits at 100 degC.
The engine makers are, of course, very well aware of this and specify oils according to engine design features, oil pump capacities, manufacturing tolerances, ambient temperature conditions etc.
If the engine has been modified, the operating conditions may well be outside the original design envelope.
Simon
