if so what specs can be said of these babies?
ekona wrote:He's not the only one
aaronjb wrote:ekona wrote:He's not the only one
*mutters*
Not forgetting Sean, Mark, Tom and Ste(Hass, Hass, Hass and C2 Power) in the UK at present.
and another one or two PE kits, I believe
(the guy with the black car, and wherever Perry's old kit went).
And Adam's 2ZZ-GE conversion![]()
No 2ZZ turbos in the UK yet, though..
I wonder if you could use a 2ZZ bottom end& 1ZZ top end
(to lose the VVT-L gear, since you don't need the restrictive cam profile at low revs with a turbo) with aftermarket cams.
THOR-Racing wrote:If that's Sean with the UK spec red 6 speed roadster he has our Turbo Conversion which is Charge Cooled..
Rowland wrote:Mk3 Turbo here*waves*
PowerEnterprise's Turbo BTW
~200 ish bhp with Greddy Emange and no intercooler.
Yet
Slacey wrote:THOR-Racing wrote:If that's Sean with the UK spec red 6 speed roadster he has our Turbo Conversion which is Charge Cooled..
No; I was the black'02 spec car with the first Hass kit in the country
- you guys mapped my car back in May last year.
Impressive numbers from your kit though
- I must stop by when I'm next over that way and take a look.
adamshaw wrote:As above- is the MK3 avaliable as a turbo?
