Can anyone give advice on how to remove an air circulating dump valve and what original part I would need to put it back to stock?
Its a baileys dump valve.
Thanks in advance
Race Idiot wrote:I've got a silicone L piece that attaches to the bov currently.I just thought that the bung wouldn't be secure enough with a jubilee clip on it or summat
jamuk2004 wrote:I'd really like to go back to the stock setup but not quite sure what to do..
Looking at my setup, I think there is just one missing piece which is this which is a rev 3 engine that I think is stock.
[url]https://i.ibb.co/fG2KFjT/copy.jpg
[/url]
Anyone know what part this is?
On mine, its gone and a pipe goes from there over to the dump baileys dump valve.
This is what mine looks like:
[url]https://i.ibb.co/5nD8m6Y/engine-1.jpg
[/url]
The blue cable goes over to this bit:
[url]https://i.ibb.co/VC0y2yb/IMG-20200601-160331.jpg
[/url]
So I assume I can just remove it and put a pipe straight through where the dump valve was, then pipe in that missing piece I mentioned
Any help appreciated
jamuk2004 wrote:Ahh brilliant thanks
Yes that's right I want to put it back to stock recirc.![]()
Do you know if there is anything else I would need?
jamuk2004 wrote:I'm not really a fan of the sound it makes and want the car to be close to stock as possible really.![]()
Is that a vacuum to the connect to the vacuum transmitting cable? I was thinking I could use the blue hose that currently goes the baileys dump valve would that be suitable?
