Just wondering is there a common cyclinder which ringlands go on?
I had mine go on cyc4, on standard setup/boost.
And if there was any preventative things to check while fixing a ringland, fule pump, knock sensor, other?
Thanks,
Tony
markstevieandmads wrote:Id be thinking if its failes on a standard setup then id be looking at the fuel pump.These weaken over the years and prob didnt provide sufficent fuel.
Also if it had been suffering detonation then was the correct fuel being used(normal unleaded instead of vpower etc)
b4ss wrote:markstevieandmads wrote:Id be thinking if its failes on a standard setup then id be looking at the fuel pump.These weaken over the years and prob didnt provide sufficent fuel.
Thats exactly what I was thinking, would it be sensible to replace fuel pump?
The car has 210k kms on it on the original fuel pump..
Its impossible to get 98RON in southern Ireland these days so 95ron may have been a factor too.
Thanks for the replies
T
Ryan S wrote:Get a GT4 ecu.A UK one.
