Ive noticed at lower boost
The below video demonstrates.
https://www.youtube.com/watch?v=LmlFtUYPm2U
androo007 wrote:Have you got an arc airbox or similar? Made my flutter sound louder.It's not a problem
I run with no bov too![]()
raptor95GTS wrote:daft question.Have you re-plumbed the black and white VTA valve at the BOV? The side marked B should be on the passenger side.
I had mine the other way round and it make that same noise
(rev3 rhd)
Gazza_DJ wrote:raptor95GTS wrote:daft question.Have you re-plumbed the black and white VTA valve at the BOV? The side marked B should be on the passenger side.
(rev3 rhd)
Is that retained for an aftermarket BOV like the OP has? I'm sure most aftermarket ones I've seen don't use the VTA?
