Trying to fit braided fuel hose to the stock fuel tank pressure line, ended up with the wrong parts to hook the fuel line up.
I'm utterly lost in this hose fitting world, please guide me through the fog
The wrong fitting is the AN6 solid fuel feed from the fuel tank, just behind the heatshields.
This is the part that doesn't work, seems like the tread is too short or the inner shape is wrong for the hard metal flared pipe.
http://www.ebay.co.uk/itm/AN-6-AN6-STRA ... 27e3245647
![Image](https://i.ebayimg.com/images/a/%28KGrHqIOKo8E3s37wJGUBN8i0Tt91g~~/s-l500.jpg)
All the other parts are fine at the filter and up to the fuel rail, just this one junction doesn't work and I'm too out of my depth to work out which part should work.
This is what I'm trying to achieve.
![Image](http://www.mrcontrols.com/images/tankhardline.jpg)
So what fitting is needed to connect that fuel feed corretly to a 6AN teflon, braided hose?
cheers
