Do you track your car regularly? I only ask because I have BC's on my car and wish I'd bought another set of Koni's to be honest because coilovers are just too hard for UK roads.
SuperRedMR2 wrote:
Even though my tyres have plenty of tread, they are a bit old now, so thinking that is not helping the situation..
Has the preload on been set properly on the coilovers? 4/6KG BC's shouldn't be that bad.![]()
Sorry to hijack sort of, but would a stiffer spring rate be better for a 4AGZE conversion due to more weight on the rear?
IanClements wrote:They're not too bad generally but I hit a pot hole in February and it bent the arms on on one corner(replaced now) and it hasn't been right since.
SuperRedMR2 wrote:over 8 years old..
Lauren wrote:
Toyo's are no good to be frank.Tried them once and they just ruined the handing of the DC2 I had at the time.
Too soft on the sidewalls.
I have no idea why people think they are any good.
Guessing it's because they are a bit of a budget tyre.
Better than TDF's I suppose.
Lauren wrote:2003, wow, time for a new set of boots then.![]()
AD08R's won't have that problem.Depends if you want a track orientated tyre, they will be noisy on the road and reduce ride comfort.
I stuck Michelin PS3's on the AE86, sidewall is too soft and there is just too much grip, so I wouldn't get those again.
This was in 195/50/15s.
The trouble is there is so little choice in that size.
