i have an issue with my 5sgte,
so its just normally when cruising
walpro in tank pick up pump to swirlpot and a 044 to rail 850cc injectors
apexi power fc
many thanks
Tony
ashley wrote:Did you inadvertently change your fuel pressure?
simpson_eh wrote:I have not changed fuel pressure but by adding a more powerful pump it's def going to be up, I presume the apexi would sort out the lamda
Still in stock fuelpressure sensor
danjama wrote:Sure it's not the clutch? Does it stop if you dip the clutch?
