androo007 wrote:Sterling job jim.
Did you find the canister delete created a smell of fumes in the summer?
Also, by removing the catch can to intake pipe.
does that end up getting past the filter and making the bay grubby with a fine mist of oil?
the canister delete, as long as you connect the top and bottom hoses when you remove it, any smell should still be going through the oem gas tank filter which sits next to the fuel filter.
i personally dont notice any smells with it setup like this, not even a wiff.
i removed all the hardlines that go up to the canister location too, so now the hosing/piping is just looped by the fuel filter.
is another reason why this area is bare.
(obviously never block these lines).
my oem catchcan hose that usually goes to the intake, i simply point that down by the gearbox, open to atmos, i dont even use a breather filter
(as this quickly clogs, restricting the gases), i literally have it pointing down and away.
i dont notice any gunk/crap in the area, though probably helps the engines in good health.
from this you can conclude i have no piping going to the intake, not even the idle line, which again frees up space as i then had no need for the engine hook and all the attached hardlines by the dizzy
(that hold/route the bov/a/c,idle/iscv piping etc).
