Recently fitted a greddy exhaust but the drivers side tip hangs lower than the passenger side.
What could be causing it???
[Mk2] [Turbo] Dual exit exhaust is wonky??
Re: [Mk2] [Turbo] Dual exit exhaust is wonky??
damage/ bent hangers.
Okey cheers I will have a look tonight
What can I do if one of the hangers is bent? Tap the hanger with a rubber mallet and force it back into shape?
TheCombover wrote:Okey cheers I will have a look tonight
Pretty much, just do it a bit at a time and check that it's starting to line up... you can always heat it also however it could be another issue. I had a similar issue once and I put washers under a mount to lower the exhaust to the correct position
Oh washers sounds like a good idea actually! I will give that a go this weekend
