Dannyc wrote:What about using a hub centric spacer to clear the brakes?, you could keep your existing wheel.
raptor95GTS wrote:I also have the same issue with BBK but daft question..
What are you going to do with the alloy that has the puncture? Where are you going to store that to drive home after taking it off? Someone on here used the OEM spare but fitted it back to front, I'm sure they'd also modified it in some way but i cannot remember how
