androo007 wrote:Excited to see what you get Rob.
What's the number dyno telling you at the moment?
I'm not sure, I know what power I'd like, but I'll wait til sat before shouting my mouth off! I drove it to my parents house and back today, the new wastegate Spring has really woken it up.
I'm pretty sure it's at least as quick
@11psi on this turbo as it was on 18psi on a ct20
- hard to be sure though based on 18 months break from driving it and only really giving it part throttle etc now.
I did, however, have an odd misfire today.
It drove mint on the way to my mothers house, then when I went to go home I got a couple of miles from their house, and it started missing at idle and crawling in traffic, afr was swinging rich/lean on the wideband sensor and it was stumbling and farting on.
I spun round, pulled into a shell station and topped the tank off
(it was on just under 1/4) in case it was the sender reading wrong and I was running out of fuel.
I plugged my laptop in and started logging via FCedit and drove it back to my mams, checked the log, no obvious bad data, checked all the usual stuff
- plugs, leads, injector connectors etc etc and all was fine.
Left it for 10 mins and it started up and ran fine, drove it home with no issues at all
- very strange.
All the ignition components are new or near new, injectors are brand new, nothing
'obvious' that would cause it.
I'll double check all earths etc tomorrow, do a check on the coil etc, hopefully it's just a freak blip and it doesn't come back.
