Harness without rollcage
Re: Harness without rollcage
I'd be surprised if you can fit those into an MR2, I have a pair of similar style harnesses
(but without the inertia reel) that are intended for use in a 4 seat car and there was no way to get the straps short enough to fit in an MR2
Actually they have been spotted
(and possibly used) by an IMOC'er in the past, I just can't remember which thread I've seen them on
kaiowas wrote:I'd be surprised if you can fit those into an MR2, I have a pair of similar style harnesses(but without the inertia reel) that are intended for use in a 4 seat car and there was no way to get the straps short enough to fit in an MR2
Checked with him on the phone.
Ok phase one.
.unsuccessful.
The distance between the firewall and the back of the seats is too short.
With the quick release system attached, the section where the belt loops around, is already touching the back of the seat.
I'm guessing that in the event of an accident, the inertia reel wouldn't have enough distance to click as the belts themselves would yank on the back of the seat and cause IT to take the force.
Clearly no go.
Sooooo.
They are going to look at removing the quick release system and just have the belt come directly from the reel itself.
No reason this can't be done, and it would suit the MR2 perfectly
The only reason the quick release is on, is for 4 seater cars where it would anchor to the back seats.
You can then remove it when you need the back seats.
It forms about 15cm of the distance behind the seat, so with this removed, it would be MR2 friendly.
I'll keep updates coming.
WHEN this works, I'm guessing there would be great interest in a group buy with some discount?
Sooooo.
Well, you were right.
I will definitely be up for a set of these, just need to finish fitting my seats first
Lefty1991 wrote:I will definitely be up for a set of these, just need to finish fitting my seats first
You're a wise man.
As Luke is a sub division of Corbeau, they can also put either badge on too
mr2nut123 wrote:Lefty1991 wrote:I will definitely be up for a set of these, just need to finish fitting my seats first
You're a wise man.![]()
They look fantastic too
http://s32.postimg.org/qefe42zdh/20160513_193342.jpg
As Luke is a sub division of Corbeau, they can also put either badge on too![]()
Who have you brought them through? How long do you think until ou get the modified set?
Lefty1991 wrote:mr2nut123 wrote:Lefty1991 wrote:I will definitely be up for a set of these, just need to finish fitting my seats first
I got them direct from Corbeau.
Awesome, look forward to seeing how you get on
Good news!
Belts done and dusted.
Saved about 16cm in total which will give it more than enough room to lock before touching the back of the seat.
I will possibly get them back for the weekend.
If so, they'll be done by Sunday night
The future of MR2 harnesses
That's looks smarter than having the extra buckle
mr2nut123 wrote:Good news!Belts done and dusted.
I will possibly get them back for the weekend.![]()
Im heading down to Corbeau's head office in St Leonards on Sea this friday to try out their Pro-Series seat.
has it been this office you've been speaking with to get it sorted for mr2 application
BUILD THREAD
: http://www.imoc.co.uk/forums/viewtopic. ... highlight=
JLW wrote:mr2nut123 wrote:Good news!Belts done and dusted.
http://s32.postimg.org/n10rrs1j9/IMG_0462.jpg
Im heading down to Corbeau's head office in St Leonards on Sea this friday to try out their Pro-Series seat.might have to talk to them about these belts.
has it been this office you've been speaking with to get it sorted for mr2 application?
Pm'd
Firewall drilled last night.
Directly behind the seat and about 10 degrees down, there's a perfect spot to drill and attach the spreader plate in the engine bay side.
It clears the engine bay mounts by a few cm and looks nice and tidy.
I would have had them done last night.
.but I found that the included 1" 7/16 bolts didn't quite have enough length to pass through the interior carpet and thick firewall.
I'll be getting some 2" replacements today and should have them installed in the next few days.
Progress pics to come
I'll report back this info so that when A group buy happens, they can include suitable bolts for our motors.
mr2nut123 wrote:Firewall drilled last night.![]()
I would have had them done last night..
Pictures will be good, where are you planning on bolting the lap belt to?
I'll have to get all the info for these off you incase a group buy doesn't happen because I want these either way
subbed
jimGTS wrote:subbed
Well.
It works a treat!! Inertia reel harness in an MR2!
I did a quick video but will add a detailed how to when I get access to a PC and not just on my phone.
https://youtu.be/Qw1hxCwWLjw
mr2nut123 wrote:jimGTS wrote:subbed
Well..
.the answer we were all looking for is a here.
*drum roll*
Awesome, how do I order mine?
Lefty1991 wrote:mr2nut123 wrote:jimGTS wrote:subbed
Well..
*drum roll*
Give a chap called Keane a call on 01424 854499 and tell him that Luke sent you.
Things you'll need:
2x Grade 8 bolts.
4 x Spreader plates.
1 x 12mm metal drill bit and drill.
Socket set with various ends between 10-15mm.
I'd recommend 2 inch bolts so that you can allow the spreader plate to grip the thread when going through the firewall.
The reason I advise 55mm spreader plates for the inertia reel, is to keep the angle of the belt as horizontal as possible.
Also, ensure that you get your bolts from a reputable place and not eBay.
