![Smile :-)](./images/smilies/icon_smile.gif)
![Image](http://i1008.photobucket.com/albums/af201/madmattyturner/IMG_8842.jpg)
![Image](http://i1008.photobucket.com/albums/af201/madmattyturner/IMG_8846.png)
![Image](http://i1008.photobucket.com/albums/af201/madmattyturner/IMG_8844.jpg)
![Image](http://i1008.photobucket.com/albums/af201/madmattyturner/IMG_8843.jpg)
![Image](http://i1008.photobucket.com/albums/af201/madmattyturner/IMG_0977.jpg)
![Image](http://i1008.photobucket.com/albums/af201/madmattyturner/IMG_0980.jpg)
![Image](http://i1008.photobucket.com/albums/af201/madmattyturner/IMG_0466.jpg)
Engine, Head
Eagle Con Rods
ACL Race Bearings
HKS double valve springs
HKS 87mm pistons 8.5:1 comp ratio
HKS 1.6mm steel HG
HKS 264 cams
Piper Vernier Cam Gears
ARP head studs
ARP flywheel bolts
ARP conrod bolts
Fuelling
Custom Made Fuel Rail
1000cc Precision Top Feed Injectors
Sard Fuel Pressure Regulator
Walbro 255lb fuel pump
Braided Fuel Lines
Turbo
ATS Racing Garrett GT3076r kit with screamer pipe
44mm Tial WasteGate
ATS Racing 3 Downpipe
Custom made 3 SS exhaust system with HKS Back Box
Stock Rev 3 Manifold
K&N 12 Air intake system with 4 Custom made pipe
Turbo smart blow off valve
Cooling
Greddy SMIC
7.5 Spal Fan Kit
Polished intercooler pipework
Samco hose
Electronics
Hydra Nemises ECU fully mapped by Momentum Motorsport
Launch control
Anti Lag
Blitz dual SBC Boost controller
Blitz Turbo timer
Defi Oil pressure Gauge
Defi Oil Temperature Gauge
Guages mounted in Mr2 Eddy A pillar Pod
Custom Oil Bung sensor for Oil Temp
Anti Lag, Launch Control, Nitrous
Speedhut Plasma Dials
Nitrous
Direct port nitrous injection system
Nitrous purge kit
Polished inlet manifold
11Lb nitrous Bottle
Suspension
BC Racing Coil over Suspension
Cusco Front
4 New OEM droplinks
Transmission
ATC Racing Clutch kit
Fidanza Lightweight Flywheel
Rev 3 Gearbox with LSD
Exterior
Full Veilside Bodykit fully smoothed into body
Side strips removed and smoothed
Aftermarket Wing Mirrors
Toms Air Scoop
Custom paint Lambourgini candy apple blue
Tinted windows
Smoked front sidelights
Rev 3 rear lights
Supra MK IV side lights
Xenon HID kit HI/Low 6000k
Crystal Clear Head Lamp Lenses
Wheels
17 x 8 Rota Torque
18 x 10 Rota Torque Drift
Brembo 4 Pot Front Calipers Custom Painted
Performance Friction Two piece front discs
Grooved and drilled brake discs and high performance mintex pads
Braided Brake lines Front
In Car Entertainment
Vibe 6x9 Speakers
Vibe 5
Sony Mex-bt5000 Headunit with bluetooth
Interior
Momo Millenium steering wheel
Nos steering wheel buttons buttons
TRD Gear Knob
Carbon Fibre Aircraft toggle switch x 4
Genuine Recaro Bucket Seats
Speedhut plasma dial Kit
Other
Polyurethane Engine Mounts
Custom painted rocker cover
Polished oil catch can
Air Conditioning unit removed along with engine pulley
Hydralic engine stay
New Oil Pump
New Water Pump
8495.
