Replaced window mechanism now its coming up too far
auzzam
Post by auzzam »
Hi guys,
As the title says, I've just swapped the window mechanism on my rev3 from a rev5 as the window motor mounts were snapped on the original.
Anyway just finished putting it all back together and I noticed when the door is open and I roll the window up it comes up a bit too far (through the wing mirror plastic) this means I can't close the door as the glass hits the rubber on the roof/pillar.
If I close the window with the door closed it works fine as I guess the window senses it can't go any higher. I'm a bit worried one day someone will be driving my car (or I may forget) and put the window up while the door is open then shut the door which could possibly result in a shattered window!
Is there any form of adjustment I can do or any ideas on why its happy to rise as it pleases?
There's slight play in the window so I can pull it up whilst its still in the mechanism, not sure if that helps.
Auzzam
abovetherim
Re: Replaced window mechanism now its coming up too far
Post by abovetherim »
auzzam
Post by auzzam »
abovetherim wrote:Image
Thanks abovetherim!
Just looking at the pic alone I think I took off one of the window stops which would explain things! will put it back in and give it a go
