Hi folks,
I'm in need of the part number of the little black...plastic grommet that sits below the door catch on the inside of where the door sits...will put up a photo of the part later but the clips in mine have broken off so I really need a new one
Part number needed!!
Mk1b 1989 Mica Blue
Mk2 rev3 1993 NA Turquoise
Mk2 rev5 1999 Cosmos Blue with st215 conversion 😉
Re: Part number needed!!
If no one comes through, I've always found my local Toyota dealership parts department to be able to locate parts for me - depends how helpful they are tho!
If you take a picture of the location of the part I'll try and find the part number for you. Also what's the year and model of the car?
Sorry about the wait folks, went to a Toyota garage and they couldn't find the part....said I would have to pull the plastic blank off to aquire the number but I ain't doing that so....here it is anyhow if anyone can help me
[/URL][/img]
[/URL][/img]
Mk1b 1989 Mica Blue
She's a 1993 na but I believe the blank is common throughout the mk2 lifespan can't wait for a reply!! 🙈
Mk1b 1989 Mica Blue
That is where the door control switch is located, I've checked the EPC and cannot find a blanking grommet listed, only the switch.
Hmmm right 😓 looks like I'll have to find some second hand ones then 😅 issue is the clips that hold them in get so brittle 😓 anyhow thanks folks
Mk1b 1989 Mica Blue
73173-14010 COVER, FRONT SEAT BELT HOLE, RH
73173-14010 COVER, FRONT SEAT BELT HOLE, LH
Aaahhh haaaa! Sir you are a star! Thank you!!!
Mk1b 1989 Mica Blue
jon wrote:73173-14010 COVER, FRONT SEAT BELT HOLE, RH
Good find, wasn't expecting to find them on the seat belt section of the EPC!
Well folks thanks for the help but it seems the part has been discontinued so...I don't know how I'm going to manage taking one of another car without the clips breaking but I will try my best!!
Thanks again though!
Mk1b 1989 Mica Blue
You could buy them from here but it will take a week or two tocome https://www.amayama.com/en/search?regio ... 3173-14010
Tried to but some yesterday but even they have them out of stock and are saying that they are no longer produced so it's not looking good 😑
Mk1b 1989 Mica Blue
They are listed under seatbelt because that little arm controls the seatbelt retractor mechanism - it is not a door/lighting control switch.
