Looking for views on gauges
ryanaj79
Post by ryanaj79 »
hey folks, I know theres been other threads about gauges, but just looking for other views on what I'm thinkin of doing.
My 2 came with an original Defi MK1 module and boost gauge, shown in pic below, however the original owner placed these on passenger side and top of dash. Have most likely been on since around 1998-99 as they were discontinued not long after.
I've acquired 3 more original gauges that are the same as the boost one, water temp, oil temp and oil pressure.
Now I've thought about where to place these, ideally I want the 3 ive bought above middle dash, and move the boost gauge to right of steering wheel,
I looked at gettin another set of dash panels and adding them in where the vents are, (as others have done) only prob is they 60mm and I like using the vents, especially in summer for air con :)
Only problem is I would need to try an remove the adhesive used for the original gauge and module (as I was gonna put module in the glove box), and they are on solid,
and dont want to damage the dash removing them, as I know they would leave marks. So I was thinking of just adding the other pods straight to the dash tops, shown
Image Image
I'd read about the guage pods above dash and piller pods that mr2eddy made, they do look good and would prefere them, but dont know if he still does them.
Has anyone removed a pod adhesive from a dash successfully before?
Draven
Re: Looking for views on gauges
Post by Draven »
You can find the gauge pods in the forsale section quite often if you're patient.
I don't believe anyone makes them any more though.
This is mine:
It's a Blitz dash mount 3x60mm pod, fitted with 52mm reducer rings for the 52mm gauges.
They come up from time to time. Might want to give MR2eddy on here a shout, as he used to do copies of them. :thumleft:
ryanaj79
Post by ryanaj79 »
aye, ive been having a good look thru and alot of google searches, but I'm late to the MR2 scene lol, so missed out on a lot.
And dont want to wait many months for a 2nd hand centre dash one to appear.
also the only piller pods ive seen are for T-bar mr2s (one in link), not seen any for tintops? tho this one is a bit pricey?
http://www.ebay.co.uk/itm/TOYOTA-MR2-MK ... Swv0tVR3Zi
If I couldnt find any pods then I was seriously thinking about the vents in the dash, (tho I'd find another set of panels to butcher, as dont want to ruin any original parts)
but like I mentioned, I like the vents for air con, and Id be left with trying to remove the adhesive from where the boost gauge is atm :(
ryanaj79
Post by ryanaj79 »
RedMR² wrote:This is mine:
Aye, thats the type I'd like, will find mr2 eddy and send him a message. Blitz and Greddy dont make them any more do they from what ive seen?
I've also got a twin 52mm on the a pillar. Got it from speedhut in the us. I think they still make them. Cost about £50 inc del if memory serves. :thumleft:
ryanaj79
Post by ryanaj79 »
I've seen the twin pillar pods from them, seen some on ebay too, cant find any single ones tho. Did you have to glue the 3 pod unit onto the dash?
Will keep looking tho for pods, might have to get a twin one and chop it haha
saw this on ebay, not the best, but could chop it, as its a 60mm one
http://www.ebay.co.uk/itm/Toyota-Mr2-Mk ... SwbdpWaVF6
wouldnt screw it in place, but once again, means using adhesive?
ryanaj79 wrote:I've seen the twin pillar pods from them, seen some on ebay too, cant find any single ones tho. Did you have to glue the 3 pod unit onto the dash?
Mine isn't glued. I wanted it permanent. Glue is messy. Mine is bolted to the dash board undeneath the pod, so no fixings are visible. Just looks sat on the dash. An additional hole for a mini wiring loom that was made. No wiring is visible either. :thumleft:
C35Rob
Post by C35Rob »
Image Replaced With URL For Quote http://i3.photobucket.com/albums/y98/Re ... dfwgu5.jpg
This is the one, still available in japan last time I checked. Border also make a twin gauge pod that mounts either side of the standard clocks
http://www.rhdjapan.com/border-tri-eye- ... panel.html
http://www.rhdjapan.com/border-dual-met ... -sw20.html
mr2magic
Post by mr2magic »
shinny
Post by shinny »
Very poor photo, but here's my 5 Defi gauges, plus digital AFR gague built into a matching 60mm housing...
In my experience, I find it easier to glance at pillar pods than the dash pods.
The pillar pod is for gasses: EGT, Boost, AFR
The dash pod is for liquids: Water temp, oil temp, oil pressure
I've replaced the stock boost gauge with a stock battery gauge.
My dash pod is a genuine hyperrev pod and the pillar pod is an MR2Eddy creation. Both are excellent.
This is the dash pod:
This is the pillar pod (before I got the dash pod and extra gauges and modded the Defis to be "bluer"):
ryanaj79
Post by ryanaj79 »
awesome :thumleft:
I've seen your pics on another thread shinney, would love that look,
only prob is my defi's have a green back light, so changing the dash backlights to match,
I also messaged mr2eddy an he still does them too, so ive got some options,
suppose Im being fussy, but not wanting to affect the cars value, so which would be best option?
Race Idiot
Post by Race Idiot »
I've got 3 52mm gauges crammed in an omori single din mount below my headunit.
It barely fits, but I prefer it to drilling holes into the dash or pillar mounted gauges.
I should learn how to fiberglass and just make a new version of that hks glovebox gauge mount.
C35Rob
Post by C35Rob »
This is my set up
Greddy profec on the steering column, aem uego in the vent and a Greddy multi D/A in the corner of the dash
The multi D/A does boost, oil temp and pressure, water temp and battery voltage, has peak recall and warning settings on all readings, backlight colour can be changed (7 different colours) as can the warning sound etc. it'll do EGT and fuel pressure too but I haven't bought the sensors for that (yet)
It wasn't cheap (£500ish if I remember right) but still cheaper than a set of defi to get the same info, and personally I don't like A pillar pods - they're too intrusive and distracting for me.
C35Rob
Post by C35Rob »
http://www.rhdjapan.com/apexi-din-gauge ... meter.html
I like these too, they look good integrated into a double din stereo hole
shinny
Post by shinny »
Rob - East Coast Imports wrote:http://www.rhdjapan.com/apexi-din-gauge ... meter.html
Oooh, now they're cool! :thumleft:
Race Idiot
Oh man, id be tempted to get that if I could find a place for my wideband!
