Hi guys fitted a new 1.3 cometic hg with new standard head bolts and the heads on but I've spotted a slow steady drip of coolant running down the engine to the ground.
It's coming from cylinder 1 side on the intake side of the engine.
If I finish building it and start it the leak will p1$$ out. Anyone any ideas what may be causing it?
There's defo something split/leaking, doubt it'd be the block but you never know.
Going to have to pap it into a garage as I can't get the time with it that I need and I want it running again asap!
Cheers for the input!
