All main ends are fine.
7 out of 8 rod bearings are fine except this one.
![Image](http://i72.photobucket.com/albums/i200/superredmr2/Mobile%20Uploads/F4D6EBA7-0A47-49B1-BAC2-99F76600D7D5_zpsmhzfidxf.jpg)
SuperRedMR2 wrote:Paul the engine you supplied me with came with 3 off no.2 rod caps and 1-off no.1
Number 1 cap was on the correct piston but the rest I couldn't do much with..
Number 2 was on number 2 piston and this is the one with wear and the others okay.![]()
Yes there have errors but my mathematical skills from 1-4 are okay if I had the correct bits to begin with.
LimeyMk1 wrote:SuperRedMR2 wrote:Paul the engine you supplied me with came with 3 off no.2 rod caps and 1-off no.1
From what I recall the numbers aren't anything to do with the position in the engine(cylinder 1,2,3,4) but the size of the bearing that they take.
There is an M stamped across the join line between the cap and the conrod.This is what you look for to make sure the cap is on the right way round and matching the conrod.
I can't remember if there is a corresponding cap
& conrod size number but I don't think that the caps were ever meant to be replaced, just the whole conrod.
Bearing replacement etc is pretty thoroughly covered in the BGB.
