Wing mirror rubber
tiff_lee
Wing mirror rubber
Post by tiff_lee »
I've had a good search but not really come across anything, is there a part number/replacement part for the rubber that goes between the wing mirror and the door? the window runs up inside this rubber but it seems to be separate from the actual door seal itself.
juliankv73
Re: Wing mirror rubber
Post by juliankv73 »
tiff_lee wrote:I've had a good search but not really come across anything, is there a part number/replacement part for the rubber that goes between the wing mirror and the door? the window runs up inside this rubber but it seems to be separate from the actual door seal itself.
Heres the part numbers for the mirror rubbers:-
ChrisW wrote:
juliankv73 wrote:Are the mirror rubbers available (where the glass rises up to) as mine are split :/
Those rubbers are part of the mirror brackets:
67514-17020 (left hand side)
67513-17020 (right hand side)
And heres a link to a selection of door and tbar rubber seals that Scott BArton found when looking to order for his mr2 .
http://www.imoc.co.uk/forums/viewtopic. ... ght=rubber
HTH :thumleft:
tiff_lee
Post by tiff_lee »
Ah excellent thank you, I can see this car getting expensive!
