Rev 2 Turbo T-Bar driveshaft issue
TotalControl
Post by TotalControl »
1st post here so apologies if this is in the wrong section.
I have a Rev 2 Turbo in T-Bar flavour that is an import. The drivers side driveshaft has broken so a new one is required. I understand the NA driveshafts won't fit as they are slightly different.
My question is, is the Rev 2 driveshaft specific to that era as the newer revisions had uprated engines and higher power output? Can a driveshaft from any Turbo revision fit?
Thank you in advance.
thomp1983
Re: Rev 2 Turbo T-Bar driveshaft issue
Post by thomp1983 »
Turbo shafts differ between lsd and non lsd gearbox but all the revisions are the same
TotalControl
Thank you for that. Will ABS have an issue in locating the right product also?
Peter Gidden
Post by Peter Gidden »
TotalControl wrote:Thank you for that. Will ABS have an issue in locating the right product also?
Absolutely!
Where is the d/s broken?
TotalControl
Haven't had a picture sent to me yet by the garage so will try to request one, or at the least some indication of where the issue is.
I'm guessing opposite side to gearbox link is easier to fix/replace?
Peter Gidden
TotalControl wrote:I'm guessing opposite side to gearbox link is easier to fix/replace?
Mzkes no difference.
TotalControl
Had a look and the car doesn't have ABS and I'm pretty sure it probably won't have an LSD.
I took a picture but the inner side of the driveshaft has pretty much shattered, so no point in uploading it.
I'm hoping the inner side of the DS can be rebuilt, but not holding my breath for the chance.
Not sure where to look now for one.
Peter Gidden
I will have what you need.
I'll PM you.
TotalControl
Many thanks. Awaiting PM.
TotalControl
Cant post images yet
If they don't work remove the space between h t t p and :
h t t p ://i609.photobucket.com/albums/tt176/TotalControl84/Mobile%20Uploads/IMG_20150623_124003.jpg
h t t p ://i609.photobucket.com/albums/tt176/TotalControl84/Mobile%20Uploads/IMG_20150623_124014.jpg
thomp1983
Post by thomp1983 »
