Hi guys!
Me again!! My car seems to be nothing but trouble! But recently the 6 Bolts on each driveshaft come loose - the bolts found near the gater- I've tried everything!! And even loctite and they still just fall out, what the bloody hell is happening!! The threads are fine they screw in perfectly it's just the seem to vibrate loose no matter what I do!
Any advice on how to get these to stay in? It's a constant worry every time I use the car if they are done up properly
Bumble-bee wrote:I wiped the screws clean but inside the thread it still greasy? How do I clean that? Or should the loctite work on that?
I only ever spilt a CV joint when i'm overhauling it, so i wash it out in the parts cleaner prior to reassembly.
Loctite will not work on greasy threads.
thomp1983 wrote:You are using a torque wrench to tighten them properly?
What torque should they be set too?
And yeah I'll wipe some cloth in the and then spray brake cleaner in there and put more loctite on and then torque them up hope it all works properly after that
There just socket heads from memory, halfords do individual hex sockets to fit a ratchet for about £5, you'll probably want a 3/8th drive version due to access which if your torque wrench is 1/2inch drive you'll need a 3/8th to 1/2inch adapter again halfords will have one on the shelf
