Advice Please - Rev1 Timing Markings?
IMR2T
Post by IMR2T »
Hi guys, my Rev1 Turbo chewed its timing belt and I'm trying to line up my crank pulley and can pulleys.
There's no obvious markings, what do I line them up with before putting my new timing belt on?
Any input is appreciated.
Peter Gidden
Re: Advice Please - Rev1 Timing Markings?
Post by Peter Gidden »
The markings are onthe engine.
Crank pulley at TDC
Cam pulleys each have a hole in one spoke. Line up the tooth adjacent to the hole with the indent in the backplate.
IMR2T
Post by IMR2T »
That's great cheers mate!
Is the crank at tdc 12 o'clock as I look at it or 12 o'clock relative to the engine angle leaning to the left?
Peter Gidden
IMR2T wrote:That's great cheers mate!
The crank is at TDC when the mark on the pulley lines up with 0 degree pointer on the timing cover.
IMR2T
Post by IMR2T »
Ok, there's a square edged notch on the crank pulley that a big washer on fits one way over, is that what lines up with the crank case mark yeah?
Peter Gidden
IMR2T wrote:Ok, there's a square edged notch on the crank pulley that a big washer on fits one way over, is that what lines up with the crank case mark yeah?
Correct.
IMR2T
Post by IMR2T »
Will I line the middle of the notch or right hand leading corner of the notch?
Peter Gidden
IMR2T wrote:Will I line the middle of the notch or right hand leading corner of the notch?
Middle. It should only be about 1-2mm wide.
IMR2T
Post by IMR2T »
Excellent mate, thank you.
One last question, I'm swapping the water pump, I've taken out 4 bolts, there seems to be a star screw located on the top right corner, is this stopping the pump from coming off?
Peter Gidden
IMR2T wrote:Excellent mate, thank you.
Water pump assembly is secured to the engine by 3 main bolts into the block, possibly another into the backplate (depending on revision), and two nuts at the rear.
If you've bought just an aftermarket water pump, as opposed to a complete water pump assembly from Toyota, you'll need to remove that Philips bolt when you've removed the assembly.
Chances of removing the Philips bolt is slim. It's loctited in, and the head normally strips.
Always better to buy a complete, ready built assembly from Toyota.
IMR2T
Post by IMR2T »
Yeah, I've just got an aftermarket pump.
Noticed the screw head was stripping. What a pain in the ass!
Is there a guide to removing the water pump assembly?
Peter Gidden
IMR2T wrote:Is there a guide to removing the water pump assembly?
Yep.
My previous post.
IMR2T
Post by IMR2T »
Haha, not really what I'm looking for but got one with pics and indepth instructions, thanks anyway mate.
Peter Gidden
IMR2T wrote:Haha, not really what I'm looking for but got one with pics and indepth instructions, thanks anyway mate.
4 bolts and two nuts. You need pictures? :?
IMR2T
Post by IMR2T »
Going to crack on with it tomorrow morning, if that's simple I'll be happy.
But tbh nothing's been simple so far...
Peter Gidden
IMR2T wrote:Going to crack on with it tomorrow morning, if that's simple I'll be happy.
Most jobs won't be on a 25 year old car that has had little routine maintenance.
