Changing A Timing Belt - Can I call you for advice asap please
IMR2T
Post by IMR2T »
Hi guys, my timing belt snapped on the way to my mot on a project MR2 Turbo I'm restoring. Gutted.
Doing the job on my drive.
Would really appreciate being able to chat to someone on the phone to see the easiest way to do this on a Rev 1.
Peter Gidden
Re: Changing A Timing Belt - Can I call you for advice asap please
Post by Peter Gidden »
thomp1983
Post by thomp1983 »
Good news is it's a non interference engine so it shouldn't have done any damage, it's not the worst belt change in the world to do, make sure you do the tensioner, pulleys and water pump as it's likely one of those seizing that's snapped the belt not just the belt itself expiring
acf8181
Post by acf8181 »
thomp1983 wrote:Good news is it's a non interference engine so it shouldn't have done any damage, it's not the worst belt change in the world to do, make sure you do the tensioner, pulleys and water pump as it's likely one of those seizing that's snapped the belt not just the belt itself expiring
Are you sure? I've read otherwise on autodata
acf8181
Post by acf8181 »
Oh, its a turbo....i was meaning about n/a, have no idea on turbo
Draven
Post by Draven »
the 3SGTE is a no-interference engine..
the 3SGE is also a non-interfernce engine.
Peter Gidden
Draven wrote:the 3SGTE is a non-interference engine..
acf8181
Post by acf8181 »
Nice one, i won't worry so much about having no record of a belt change then.
mark_buk2003
Post by mark_buk2003 »
I have just purchased a mr2 rev3 and the guy I bought it from also said they are non interference engines,, so yes engine should be fine atleast
IMR2T
Post by IMR2T »
Gutted, checked coolant level and it's very low.
Took off cap and coolant started leaking from behind the cam cover...I only ordered a belt and tensioner...looks like I'll nd a pump as well...can cancel Monday's MOT as I doubt anyone will have one on a Sat.
