Uuuuh, does anyone else drain their doors?
JD
Post by JD »
- Both doors have rust in the popular place at the very bottom, due to owners not draining them regularly. This is the only rust on the car.
Have I missed something?
EDIT: "For Sale Ad" Link removed by IMOC Moderation Team
synXero
Re: Uuuuh, does anyone else drain their doors?
Post by synXero »
As far as I am aware there is nothing at all you can do about stopping the doors rusting. I've certainly never heard of draining them. They do have small round drain holes but how you'd remove the fluid I do not know. Short of maybe a dehumidifier in the garage.
JD
Post by JD »
Only problem with rust on doors I've seen is on the bottom corner/edge where clumsy passengers have dragged them on high curbs :(
acf8181
Post by acf8181 »
JD wrote:Only problem with rust on doors I've seen is on the bottom corner/edge where clumsy passengers have dragged them on high curbs :(
take door card off and look inside at the bottom.....i bet you find some rust! i know mine has, so kurust'ed and dynax'ed in there
JD
Post by JD »
Okay might well do that, cheers. I'll get in there with the dremel if I find anything and sort it out. I may as well do a window alignment while I have the cards off, too.
Rob
Post by Rob »
You can't avoid the rust, it has nothing to do with the drains.
Basically the outer skin folds around the inner door skin and is sealed with seam sealer. Water collects on the seam sealer and when that eventually fails the water gets in and rots from the inside of the 2 folds.
Cavity wax is better than nothing but keep an eye out for failed seam sealer.
danjama
Post by danjama »
That's my ad and yes it is a common issue on our cars.
Thanks for the thread though, good info here :)
That's a good point about the corner edges, my NA had that, luckily my turbo does not.
RazzyRascal
Post by RazzyRascal »
Ha, I have to 'drain' my ns door as water collects in the rubber trim at the bottom. I've heard the little drainage channels along the top can block, however I've never looked myself.
JD
Post by JD »
danjama wrote:That's my ad and yes it is a common issue on our cars.
:lol: small world :thumleft:
GLWS
rev3gtturbo
Post by rev3gtturbo »
Rob wrote:You can't avoid the rust, it has nothing to do with the drains.
What does failed seam sealer look like?
I don't know anything about car bodywork design/manufacture but for some reason I imagined the 2 folds would have been welded and the drain holes let any water out if the holes don't get blocked.
As road dirt/mud can accumulate on the 2 folds it would also hold moisture against the metal making it easier to rust?
So when I wash my car I also go over the 2 folds (and rubber door seals) with the sponge. I guessed that if they can get wet by driving in the rain, then keeping them clean with a bit of wax protection might help.
I don't know if it helps, but I have been doing this for about 14 years with MR2s and not had door rust.
