CT20b screamer pipe
em1_matt
CT20b screamer pipe
Post by em1_matt »
I know this gets covered by no doubt a select few numptys that ask this question.
However I get the serious horn for the noise of a screamer pipe. My current turbo on my Rev3 GTS is spot on, in perfect condition, however I want the noise.
What is thre best way to go about this. I know I need an externally gated turbo which the CT20 is not so would need welding up. is this a waste of a fantastic condition turbo.
I will be intending on getting an uprated Intercooler or a charge cooler setup and only slightly upping the boost.
What are people recomendations to me.
shinny
Re: CT20b screamer pipe
Post by shinny »
I recommend you leave it alone. I've been down the route of external wastegate on the CT20b - it was a very expensive experiment which I have now abandoned.
If you absolutely must have a screamer pipe (which will make track days tricky due to noise) then the solution would be to swap the turbo entirely.
em1_matt
Post by em1_matt »
That's for the reply.
I thought this would be he case. Plus I don't really want to sacrifice the acuity to do track days.
Thanks Matt
