Car Scissor Lift (mobile)
shane34
Premium Member
Post by shane34 »
Hi guys wondering if any of you have one or know someone that has, for home use using 240 power in there garage.
Ive looked about online, im going to be looking around the £1500 ish. ideally i would want the center section free.
any input would be great thanks.
juliankv73
Re: Car Scissor Lift (mobile)
Post by juliankv73 »
Hi Shane
Any good??
This scissor lift is ideal for tyre shops / body shops, with the advantage of it being totally mobile.
Features
• Fully mobile
• Lifting capacity 3T
• Extendable platform
• Lifting height 1000mm
• Minimum height 105mm
• Pneumatic safety locks
• 240V single phase
• No installation required
http://www.automotechservices.co.uk/pro ... ssor-lift/
shane34
Premium Member
Post by shane34 »
yep that is spot on thanks :thumleft: . Dimensions are tight on the length but i think with its rubber blocks it will clear. not many show a pdf of there full sizes like this site.
will probably order it today
Although i need a compressor as well for the safty locks. ha ha
MartinF
Post by MartinF »
Have you looked at MaxJax ?
http://maxjaxuk.com/
http://www.maxjaxusa.com/
May be a good option depending on your specific needs.
Blue Lexus RCF
Black MKIV UK Manual Supra
Green MK2 MR2 Tin Top
shane34
Premium Member
Post by shane34 »
cheers martin i would prefer these as the provide alot more room, but my garage would not be suitable.
shane34
Premium Member
Post by shane34 »
ordered the one Julian linked, should be here friday. :D
will start the underside detailing on both mr2's this weekend.
super
Post by super »
I'd love a garage big enough to fit that in.
Enjoy the underside of your car! :D
