How to reset the speedo clock?
Is it possible to set the speedo clock back to zero without breaking it?
Re: How to reset the speedo clock?
alan wheeldon wrote:Is it possible to set the speedo clock back to zero without breaking it?
I take it you mean the car's total mileage?
Yes that's what I mean.![](./images/smilies/spacer.gif)
If you can't then I'm thinking of getting a new independent speedo but if you can change it then bonus
alan wheeldon wrote:Yes that's what I mean.
If you can't then I'm thinking of getting a new independent speedo but if you can change it then bonus![]()
I believe they're designed so that if they're tampered with then the numbers don't line up properly.
Why would you want it back to zero? That would mess with readings for mot's and insurance.
Would probably put potential buyers off and i think it may be illegal as clocking the milage?
Though i want to know if it can be done as i need a new set of clocks and want to be able to adjust new set to read the same.
Some cars you can put a drill into where the speedo cable goes and set it away but i guess that could take a while.![](./images/smilies/spacer.gif)
RedMR² wrote:
I believe they're designed so that if they're tampered with then the numbers don't line up properly.Not 100% sure on this one.
ive read this before and whilst i cant explicitly deny it, my experience of it says that its not true.
The way i clocked them was as follows.
Ok I'll give that a try next week when I get my car back, cheers
It isnt that difficult, quite fiddly though, I did mine when I bought a new uk dial cluster and converted the mileage from KM`s to Miles and printed out a sheet to confirm it all and detailed it myself.
So if an amateur like me can do it anyone can!
Dans Modified MR2 Turbo
>>> http://www.imoc.co.uk/forums/garage.php ... e&CID=2727
As above folks have said.
I simply wound the cogs on by hand
(uses small jewellers screwdriver iirc) when I swapped to a 180 speedo.
All line up perfectly.
Very easy to do.![](./images/smilies/spacer.gif)
Nice one trev.
this could be handy if and when i ever get mine working and installed.
Jut wondering really, is there any way to change the reading from KMs to miles??
Use this to work out your miles.
http://www.calculateme.com/Length/Kilom ... oMiles.htm
1KM is like 0.6Miles roughly isnt it.![](./images/smilies/spacer.gif)
Last edited by DAN_REV1_TURBO on Sun Jul 17, 2011 8:38 pm, edited 1 time in total.
So say 80,000KM is roughly 49,709MILES as an example.
Then buy yourself a uk speedo cluster like 160MPH one, and I THINK not 100 percent but doesnt the speedo sender have to be a uk one aswell so that the clocks then add up in miles aswell? ![](./images/smilies/spacer.gif)
I fitted the cluster/reset the clocks to correct amount of miles myself and had a mate at a garage sort the speedo sender afterwards, it was on a mechanically driven rev1, so not entirely sure on a rev2 arent they electrically driven? But I imagine you would need uk speedo sender and uk cluster, someone will be able to give you a definite answer on here.
I fitted a de-limiter to the back of my rev1 cluster whilst it was out aswell bought it with the cluster dunno if its the same principle with a rev2, but you could get that done at the same time if it is, save having the dials out twice.![](./images/smilies/spacer.gif)
Edit: Sorry upoynavanje, just realised you werent the OP, so yours might be rev1 aswell for all I know
If you remove the speedo head from the instrument cluster, look at the back of the dial face and you will see the mileage wheels sitting on a shaft, clamped at the ends into a plastic mount.
clocking
when I imported cars I clocked them all, I hade the trading standards down to see I did it by the book
& all was well.![](./images/smilies/spacer.gif)
Its abit complicated so the brif version is,
its not ilegal to clock any vehicle, the offence come in not disclosing the fack the mileage has been changed, or to fraudulantly pass it off as corect in order to increase the value of the car.![](./images/smilies/spacer.gif)
on the deed its self assuming you have the covers off
& the didgits are acsesable gently open the gap on the left hand side of the didgits with a small screwdriver this tacke some pressure off the coggs when turning the nummbers ahhh in a rush so have to go pm me if you need a better explination
Thanks,
Old post but just completed successfully, and documented ![Smile :)](./images/smilies/icon_smile.gif)
