NA uprated clutch
pistol pete
NA uprated clutch
Post by pistol pete »
I am in search of a good clutch for my track mk2..
few power mods.. but most importantly Track tyres along with LSD box and a LOT of launches..
so what recomendations for a na clutch can take lots of launches ( as its in the sprint series) with track tyres.. no road use at all only track use.
I have tun a LUK clutch this year and its coped fine witht he launches.. but its the addition of track tyres i have been told will kill the clutch
cheers
Race Idiot
Re: NA uprated clutch
Post by Race Idiot »
Like I said, I recon helix would be your best bet
http://www.fensport.co.uk/Parts/Model_26/Category_3/736
Does say is more suitable for competition use and drag type launches.
thomp1983
Post by thomp1983 »
Does the 3sgte crank have the same pcd as the 3sge? If so you should be able to use a turbo flywheel and pressure plate with n/a friction disc.
That's the setup used on v6 swaps we just redrill the flywheel pcd to suit the v6 engine. It copes with the extra torque and hard launches fine
gavsdavs
Post by gavsdavs »
Super grabby, uber clamping, ACT.
Normal feel, better clamping than stock, Helix.
For a track going vehicle the ACT is a no nonsense answer.
pistol pete
Act??
pistol pete
Cheers breltt nit seen that one before
I'll drop Adrian a message about that one
GreddyMR2
Post by GreddyMR2 »
I am using Helix ceramic, can vote for that! Just not for a daily car unless you want to spin your wheels all the time you start going :)
