For me, the longer you own one of these, and become more attuned to its nuances, the better.
Unfortunately, it probably would have been better if you had made some of these suspension changes one at a time in order to see how each benefited, or hindered what you preferred in ride quality.
But I know that's not always an easy accommodation, lol.
That being said, the polys are definitely the likely suspect in your discomfort.
While they can produce more extreme feedback they can probably also produce a rather jarring effect to one who has become used to riding on an older oem type suspension.
Many probably enjoy the extra stiffness, while others will find it rather objectionable.
These cars can handle great with the oem bushings, and all the other mods.
You can't just buy new oem bushes though, as they only come installed in oem suspension arms, and the rear ones may now be discontinued from what I saw recently.
MKI TRD bushings have been discontinued for some time, but would have been a great upgrade without the extreme feedback of the polys.
If you can't get new oem suspension arms try installing a decent set of used ones.
Deterioration from age, in these bushings, is greatly exaggerated, and would be worth giving a shot.
Otherwise, while hard to obtain, I believe Cusco still produces Hyper bushings for the MKI, and are a cross between rubber and poly, so to speak.
For me, polys are best used for sway bar and strut bar bushing replacements, where they provide significant compression resistance, and better suspension accuracy without adding significant stiffness to the overall ride.
