[Mk2] [Generic] MK3 Steering Wheel DIY Red Stitching
stuMR2lee
Post by stuMR2lee »
Originally posted on MR2OC: Just thought I'd share a couple of mods I've been working on over the recent weeks:
Firstly I've replaced my Rev5 Steering Wheel with a MK3 one (my choice to lose the ageing airbag). What I didn't want to lose was the red stitch effect. So I googled a DIY way of doing it and here's the finished article:
I then decided I needed a boost gauge (my car being a Turbo conversion in a UK car didn't have one). I prefer the oem look so decided to fit a 45mm Prosport Boost a Gauge in place of the voltmeter. It was amber and a bit bright at night so I used some of the red film left over from doing my dash and clock to slightly tone it down. Now matches my stereo and clock.
The Red Stitching was fairly easy and inexpensive to do (under £6.50). You actually leave the original stitching in place and just follow it with the red over the top. Gives a good effect.
I loosely followed this guide:
http://www.8thcivic.com/forums/inside-o ... wheel.html
The red stitch I bought:
http://pages.ebay.com/link/?nav=item.vi ... ID=EBAY-GB
The needles:
And some beeswax came in handy to make the thread a bit more workable:
Slightly thicker pre-waxed linen thread would have been ideal if you can find it. The thread I used I doubled up (easier to sew that way) and run through the bees wax. I'm happy how it turned out.
Slightly better picture:
wilkie senior
Re: [Mk2] [Generic] MK3 Steering Wheel DIY Red Stitching
Post by wilkie senior »
Nice work Stuart, thanks for the advice yesterday :thumleft:
Regards Brian
stuMR2lee
Post by stuMR2lee »
Thanks Brian. You're welcome anytime my friend :D.
Rosssco
Post by Rosssco »
Nice work, but why not just fit the Mk3 airbag unit to the existing Rev5 JDM steering wheel? It just needs a small adaptor harness available cheaply from Toyota.
The mk3 (and Gen 7 Celica and IS200) steering wheel are essentially the same but with different colour stitching IIRC.
I fitted a gen7 Celica steering wheel and gen6 Celica airbag to a previous mk2. I never "tested" it mind :lol:
stuMR2lee
Post by stuMR2lee »
Rosssco wrote:Nice work, but why not just fit the Mk3 airbag unit to the existing Rev5 JDM steering wheel? It just needs a small adaptor harness available cheaply from Toyota.
If only! My car is a UK Rev5 NA (with Turbo engine conversion). The original airbag is mechanical and self contained. See my other post with further details.
Edit: http://www.imoc.co.uk/forums/viewtopic. ... highlight=
Rosssco
Post by Rosssco »
Ah ok, apologies, must be a different set up.
I thought it more simple than that, as my previous Rev4 G-Limited (NA) was a straight forward swap with a Mk3 steering wheel, adaptor harness and a celica gen 6 airbag like this one:
http://s424.photobucket.com/user/babybo ... 1.jpg.html
Does the mk3 air bag just detach from the centre pad? So you can run the wheel with no airbag? Thanks.
stuMR2lee
Post by stuMR2lee »
Yep. That's what I've done. 4 small bolts and off it comes.
stuMR2eye wrote:Yep. That's what I've done. 4 small bolts and off it comes.
Perfect. Thanks mate! :D
