MR2 Newb
Draven
Re: MR2 Newb
Post by Draven »
MR2 Livvy wrote:Thanks for the reply, saved money there,just stuck with stock.
When I'm looking at the subframe there's the tie bars, what bars are on the other side? they all look pretty shot
do you mean the rear trailing arms? a long tube type bar with bushes on each end?
MR2 Livvy
Re: MR2 Newb
Post by MR2 Livvy »
www.imoc.co.uk/forums/viewtopic.php?p=1 ... e8fe50fecb
On the rev 2. Frame
The bar over the top - arb
Closest to the camera - tie bars?
Ones obscured by the frame & poking out - trailing arms?
fozzie
ref bow off valve on mr2 rev2 turbo
Post by fozzie »
hi to all on here as i have just joined, i am looking at fitting a hks blow off valve to my rev2 turbo and wondered if it will run ok without any adjustments any help would be appreciated many thanks, i also have broken a rev3 na and have some parts for sale rear lights, engine etc do you have to upgrade membership to advertise on here? thanks
Peter Gidden
Re: ref bow off valve on mr2 rev2 turbo
Post by Peter Gidden »
fozzie wrote:hi to all on here as i have just joined, i am looking at fitting a hks blow off valve to my rev2 turbo and wondered if it will run ok without any adjustments,
Always a big debate here, so i'm sure they'll be lots of differing opinions.
If you go "by the book", i.e.what works best from a mechanical theory point of view, any engine using an AFM for fueling should never have metered air vented to atmosphere. The OEM recirc. dump valve is a high quality piece of kit. End of.
However, the "hey everybody, i've got a turbo" dump valve noise is important to many owners, and they fit them because they like them. Your choice entirely.
There are no adjustments to make after fitting one.
