Hi,
I've got a shift cable bearing kit from Peter at SBITS and have just got round to fitting it. The instructions mention to lubricate the outer bearings and bell pin. Will copper grease do the trick here, or is something like moly grease needed?
copper grease is an anti seize compound, not a lubricant. it contains copper (obviously) so shouldn't go anywhere near a bearing anyway. just use a standard multi purpose grease
