Turbo 22V rear calipers in good working order with extended carriers to suit the bigger discs.
Discs are correct stud pattern, 280mm and have loads left on them. Also includes Yellowstuff pads with less than 1k miles on them.
Will fit under 15" wheels.
Looking for £100 collected.
Big rear brakes turbo calipers 280mm discs
Re: Big rear brakes turbo calipers 280mm discs
Sheppy should take this lot!
- IMOC Moderator
synXero wrote:Sheppy should take this lot!
i think this is stock rev2+ calipers mate, but on the rear of a Mk1
If only you posted this on Friday, I would have had it all off of you!
Shame. Thought they were going with the car but changed his mind just before collection.
£100 collected. Bargain.
ARe you sure they fit under 15 inch (mk3) wheels? PW article about this upgrade mentions you need at least 16.
If they fit, can you can ship them to Belgium?
(I know it's gonna be expensive)
Sorry only just seen this reply. They definitely fitted under my 15" OZ Superlegarras, never tried them under mk3 wheels but can't see it being any different.
I can price up postage.
yup, the 22v fit under mk3 15 inch rims if you use the original mounts.
