[Mk2] [Generic] Show me your border bumper!!!
Ryan S
Post by Ryan S »
Ok, so i'm having my border front end fitted next week, i've thought of a few options for mounting the front plate but would like to see some other ideas, so let's see what you have :thumleft:
whoops, i forgot, i'm also retaining the front fogs, so if you have any opinions on that, please share.
Ryan.
aj.extreme
Re: [Mk2] [Generic] Show me your border bumper!!!
Post by aj.extreme »
Here's mine it's got two bars fitted across the middle section at a slight angle and the number plate taped to them, no cooling issues and no hassle from the local plod :thumleft:
madbasshunter
Post by madbasshunter »
Mine was here all the time I had the car
Police inspected the plate a few times but never mentioned its position but did mention the wipers position :o
RyanRs wrote:
Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously , you don't know the answer to this? and you call yourself a car mechanic :shock:
madbasshunter wrote:Mine was here all the time I had the car
^^That's a Bomex dude.
Sheppy, have a scan on google, loads and loads of Border fronted '2s. :thumleft:
madbasshunter
#-o doh that will teach me to read the post properly :oops:
Ryan S
Post by Ryan S »
aj.extreme wrote:Image
ooooh, that looks good, oddly, the border bumper i have also has the 2 bars, i am having them removed and the holes filled though, i may change my mind. i did have a wee look on google, just wondering what the guys in the club reckon, a lot of the ones i found on google didn't actually have number plates at all.
aj.extreme
I played with a lot of different options, the 2nd best was an import number plate mount in the very front middle of the bumper. Everything else looked odd "in my opinion" :whistle:
Ryan S
Post by Ryan S »
looks great man, i could be into doing this, also, where did you get the canards?? i've seen these a few times on the border now, are they generic, or specific to the border??
kayjay0_7
Post by kayjay0_7 »
Standard import number plate holder mounted on the border
^^ that's what I'd go for. I have a Bomex front and use the stock import plate holder on it.
Ryan S
Post by Ryan S »
hmmm, that does look good too, i would have to get myself a square plate, which is fine as i'm not keen on my current plate anyway :-k
thomp1983
Post by thomp1983 »
thats how it was when i bought it, ill probably be getting a slightly bigger plate as im not keen on it having no border around the letters
Ryan S
Post by Ryan S »
i'm beginning to think it doesn't matter where the number plate goes haha, they all look good!!
thomp1983
Post by thomp1983 »
if mine wasn't already drilled and mounted there id be running a reflective vinyl plate on the lower part
chris
aj.extreme
The canards are just universal fitting ones, bit marmite to be honest but I like the aggressive look. Doubt they actually do any benefit but you never know
RyanRs
Post by RyanRs »
Heres mine. Its genuine border ;D
Ryan S
Post by Ryan S »
hmmmm, i'm not too keen on that with a regular number plate :(
al/c
border bumper
Post by al/c »
here,s mine as it was Image[/URL] :thumleft: [/img]
Ryan S
Post by Ryan S »
Is that just a regular size UK plate? That actually looks better than square!
Magic Beans
Post by Magic Beans »
I mounted mine like below.
How I did it, along with how I made a flat undertray and speed flaps (well worth the work!) can be found on this page and the following page :thumleft:
http://www.imoc.co.uk/forums/viewtopic. ... start=1500
