[Mk2] [Turbo] which intercooler kit?
Currently looking for an intercooler kit but whats a good one to use? Ive seen a few arc ones for sale and one hks.
which would be the better purchase? Thanks
Re: [Mk2] [Turbo] which intercooler kit?
steelyblue wrote:Currently looking for an intercooler kit but whats a good one to use? Ive seen a few arc ones for sale and one hks.which would be the better purchase? Thanks
ARC and HKS both use very good quality cores on their intercoolers
Make sure you fit a sealed shroud with intercooler, this will force the air through the core rather than around it, see install guide here:
http://www.turbomr2.com/MR2/HowTo/Inter ... er_PG1.htm
Thanks for the advice! Ill go for the arc one then.
thanks alot
I have an ARC and can vouch for how good it is, core is always cool even after sitting in traffic or a spirited drive.
its a thick core and very interesting to fit, but well worth it.![](./images/smilies/spacer.gif)
Thanks for the advice! Ive found one for sale just awaiting the fella to get back to me then ill make the purchase.
thanks again
Nic wrote:I've read of a few concerns about the routing of the piping on the HKS intercooler on the MR2, someone else may be able to expand on this.
Yeah its ridiculous
The feed to the IC from the turbo is pretty ok, follows pretty much the factory path, give or take.
The outlet from the IC is down the back low, and the pipe
I felt improvements
I have a HKS intercooler with redesigned piping.![](./images/smilies/spacer.gif)
I fitted an EMS Powered SMIC.
It uses the chinese ebay core
(is not that bad at all), attached to a Spal fan with a very good quality powdercoated pipes, clamps and hoses.![](./images/smilies/spacer.gif)
I'm very happy with it!
How many power are you looking for? Correct me if i'm wrong.
ARC are one of the finest quality SMIC for highly modded mr2's
Regards
Regards
sky-net wrote:Correct me if i'm wrong.
I think you mean Power Phoenix intercooler
I have a cheap intercooler which has served me well but needed one of the brackets welding, the core seems fine.
I haven't taken the Pepsi challenge with it and compared with a known brand but it's better than stock.![](./images/smilies/spacer.gif)
If I'd done a bit of research I'd of waited for a decent one to come up as I took a bit of time getting my upgrades fitted but if you want one asap and fairly cheap then why not?
(Don't feel you need to answer that).![](./images/smilies/spacer.gif)
