Apparently someone did a flow test with the scoop inplace once.
It did not affect the running temps of the engine what so ever, this was down to the physics of air density and not flow direction.
Ie, the cooler air from the scoop will be more dense than the hot air above the turbo/manifold and therefore the trend will still be for the scoop air to sink before rising upward and out the lid vents.
Sounds positive! however the velocity
& heavy air sinking from the scoop increased the pressure in the engine bay making the effectiveness of the lower trays
+ side scoops Less effective
(there is more resistance pushing against the air thats trying to flow in the vents).
the result was no change in engien bay temps but a big change in flow direction through the bay.
My concern would be that the increased pressure in the engine bay will effect the downforce dynamics at the rear end and increasing instability at higher speeds.
there is also the extra Drag caused by the scoop to consider
-any possible but unlikely gain you could get from the scoop will soon be lost as speed increases and at higher speeds it will actually hinder performance.
