Brake banjo bolt washers
StevenstonWullie
Post by StevenstonWullie »
going to have to remove the banjo bolt on the rear calipers to change my struts just wondered what size of crush washers do i require ...anty help appreciated W :)
madbasshunter
Re: Brake banjo bolt washers
Post by madbasshunter »
Just cut a slit in the bracket on the strut and bend down one side so you can remove the brake hose without undoing it
you can see what I mean on this strut
StevenstonWullie
see i was thinking that ...im replacing the 2 rear coilovers on my tubby back to black billies ...on the coilovers the flexi hose is just cable tied to the strut body...would it be ok to do the same with the billies its for the MOT?...cheers fro the reply W
madbasshunter
I used these
on the coilovers
The black billies will have the proper bracket to use wont they?
StevenstonWullie
yes they will but but if i have to cut and bend them down to save me from disconnecting brake hose ...hmmm i shall see
madbasshunter
You then bend them back up and slide the u clips in to hold them in place :)
Harold
Post by Harold »
I cut a slot in each of mine so I didn't have to bend the bracket, and as above the u clips should keep the hoses in place.
going4the1
Post by going4the1 »
The washers are not 'crush-washers' They are simply copper washers. They can be re-used without problem despite what you may have read.
The washers will harden over time and when re-using it is wise to anneal them with a blow torch after which they will regain their original flexibility.
Peter Gidden
Post by Peter Gidden »
madbasshunter wrote:Just cut a slit in the bracket on the strut and bend down one side so you can remove the brake hose without undoing it
I have yet to understand why anyone that has any respect for their car and the individual components fitted to it would ever consider hacking at their struts just to save a couple of minutes of bleeding.
+1
ashley
Post by ashley »
+3
And the copper washers are crush washers, they're made of copper and squash when you tighten onto them: that's the whole point! When it comes to brakes why take a chance? They literally cost pennies to replace...do it properly :thumleft:
thomp1983
Post by thomp1983 »
madbasshunter wrote:I used these
on the coilovers
Where did you get them from buddy?
thomp1983
Post by thomp1983 »
on the coilovers
JohnnyC
Post by JohnnyC »
+4
Brakes probably need bleeding anyway.
